Buckbilly had owned a large farm for several
years.
He had a large pond in the back.
It was properly shaped for swimming, so he
fixed it up nice with picnic tables, horseshoe courts, and some
apple, and peach trees.
One evening he decided to go down
to the pond, as he hadn't been there for a while, and look it
over.
He grabbed a five-gallon bucket to bring back
some fruit.
As he neared the pond, he heard voices shouting
and laughing with glee.
As he came closer, he saw it was a bunch of
young women skinny-dipping in his pond.
He made the women aware of his presence and
they all went to the deep end.
One of the women shouted to him, 'we're not
coming out until you leave!'
BuckBilly frowned, 'I didn't come down here
to watch you ladies swim naked or make you get out of the pond
naked.'
Holding the bucket up he said, 'I'm here to
feed the alligator.'
Some old men can still think fast.
:laugh:
    • By KdlH
      Following on from this thread;
      I've finally got around to pulling the clutch cover off to have a look at the shifter ratchet mechanism. The screw holding the pinned star wheel has come loose and the wheel flops about. Unfortunately the keyway on the shifter cam has broken on both sides, I found both pieces.
      Anyone had this problem?
      The keyway on the cam "ramps" out, so I'm thinking of making a slightly longer key with a ramp ground into it. I'll put it back together with retaining compound. It may not work but I think it's worth a try.
    • By gbanker
    • By mga
      I get it, turn counterclockwise will decrease, turn clockwise will increase.  My question is what exactly am i increasing or decreasing? Is it clutch pressure? In many videos i've seen it's always "turn counterclockwise" until you feel resistance then back off. Why is it always to decrease?
      I'm just curious as to what exactly is going on when i turn that screw right or left. And, since there's no manual clutch to engage or disengage, what is going on inside?
      Reason why i'm asking is while going down a hill in 1st gear, it appears to pops out of gear, but no neutral light, and if i stop, it's in 1st gear still. BUT, (always a but) if the engine is warmed up, it stays in 1st gear. The hill is too steep to use any other gear, so 1st with the brakes is the only way to go down.
    • By mattgoodwin
      I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
