I dont think he is asking about the compression ratio... Stock compression should be 120psi plus... Im pretty sure you have to disable the auto decompression on it to get a good reading or you could do a leak down test on it...
Edited by jigolbeep
Yes, I believe stock is:
Compression Ratio 9.2x1
Compression 834 kPa (121 psi)
had my compression checked and was about 170 lbs. you think i should run higher than 91octane?
170 is pretty high, what kind of mods do you have? If it is really 170, then you should probably atleast run a mix of race and pump gas.
only mods i had when my local atv shop checked my compression what yosh pipe, moose racing jet kit, k and n filter. the guys that checked for me have been doing it a long time so i trust them. we just finished re-jetting and took air box lid off, exhast cam mod, removed spark arrester, and am waiting on rev box and 15 tooth front sprocket. we checked the compression because we couldn't get the jetting right and thought maybe a valve had messed up. have since gotten the jetting right though.
    • By Trent Finnessey
    • By DZL1
      Thanks in advance.
    • By bigd764
    • By k9_bones
      Hello, been lurking for a while fixing some of my problems after reading others unfortunate issues. However I can’t find the answers I need. Back story I have a 03 Kodiak 450. A coworker was going to take it to the dump, he said it wouldn’t run. Some mice got in there while it was stored for a few years and chewed up the wire harness. All the wheels were locked up and he didnt want to mess with it. Not knowing if it would run, for a week or so I spliced most of the wires back together. Replaced all the brake calipers and rear brake cable and rebuilt the carb. So far I have put 30ish miles on the bike and seems to run decently. Now my questions. When I put it in gear and the display light showed it is in gear I have to bump the throttle to make it actually go into drive or reverse. It doesn’t slam In gear but kind acts if you let the clutch out to fast on a manual. Is that normal, seems it’s thinking about going In gear then it goes after tapping the throttle. 2nd question, when I use the diff. Lock it acts like it is in a limp mode just by accelerating the lest little bit. It starts to sputter and won’t allow it to have any power. It only does this with the diff lock on. 3rd. The display is stuck on KMH. How do I change it to MPH. I followed all the steps I saw on YouTube with no luck. When I got power to the display it was in MPH but it switched its self and now I can’t get it back. Next are the rear u-joint the same as the front u-joints. I have sprung a oil leak from the rear diff at the drive shaft and need to replace the seal. Sorry for the long post and thanks in advance for any help. I’m sure I will find more things in the future.
