i like to post the banner when i reply, makes it easier for the next guy getting to the site. i'll keep both links on my reply from now on, just for you mario !! :cute:
Thanks Oxy! :partyc: doesnt have to be every post just so i can find it every once in a while
Holding Strong? How is that? You may be the #1 site on a Top Site, because you have a few members who actually vote, but you are not the #1 site. I have been a member for 5 days, and your lucky to get 3 to 4 post a day, that don't sound like #1 to me. A #1 site should be getting at minimum 40 to 50 post a day.
    • By flyinbrian365
      The files it too large to upload so here's a link to my dropbox.
      Hope this helps someone!!
    • By Pure_Michigan
      Hello everyone.  This is a Go Cart and not a typical "ATV" but it has an engine so I'm hoping someone can help me.  It's a Helix FTX with a Manco 150cc engine.  The engine will start and idle for awhile, but will not take even a small touch of throttle.  Stalls.  It seems to take throttle and rev up when you first start it cold, but in just a minute, it will not take any throttle.  I've replaced the Fuel valve/Pump on the fuel tank with no joy.  It's a nice little cart, but without a workable engine, it's a boat anchor.  I'm not dumb when it comes to small engines, but this one has me stumped.  I'm running out of options.
      I'll mention that while it is idling, it will sort of "cough" every 6 or 8 seconds and then recover and idle again.  Eventually one of those "coughs" causes it to stall.  It will start back up pretty easily, but as I said, it absolutely will not take any throttle and then it will cough and stall a minute later.  I thought it could be timing, but there is no "adjustment" for timing on this engine.  I downloaded the user manual and it mentions nothing about timing and is pretty much useless as a service guide.  It just shows the basics.  I'm attaching the manual so you can get an idea of the machine I'm dealing with.
      Any input would be greatly appreciated.
      Kind regards,
      Don
      Manco-Helix-6150-150cc-Owners-Manual.pdf
    • By lindzjo
      Does anyone have a service manual for Qlink 700 atv.I cant find anything on one.Please help
    • By QuadDad22
      Picked up a 86’ LT 185 for $10 in trade value(my items only cost me $10)
      recoil only , I pull the recoil and it won’t move , so I took it off , I can spin the crank there one full turn left then it locks up , and one full turn back to the right and it locks up
      pulled the plug , the piston is moving up n down , both valves are moving(pulled the caps)
      pulled the clutch off , oil pump gear , and it still locks up after one turn
      any ideas or where to go from here would be greatly appreciated
      im a 2 stroke guy so this all is new to me
      thank you in advance y’all
