      Hello there
    • By mga
      I see quite a few ads for that  Tribotex additive. It's kind of expensive, has anyone used it it their ATV or any other vehicle?
    • By Brantley11
      Hey everybody,
      My proficiency is with Hondas and Yamahas make me see RED!
      This bike is my brother in law's, it has 1199 miles on it and went from running great to dead with no start. Every once and a while it will start and sputter for 2 seconds. It is extremely sporadic when it fires but never runs for longer than 3 seconds.
      Here is where we sit:
      Brand New Fully Charged battery
      Carb was cleaned with air hose and carb cleaner then into the ultrasonic cleaner with Aircraft aluminum cleaner
      New Shindy Carb kit (made in Japan version)
      Cleaned out petcock and gas tank
      New 93 Non Ethanol Gas
      New Spark Plug
      It gets a spark through the spark test light every time
      Bluish white spark
      When holding the spark plug 1/4" - 3/8" away from head it will jump and spark to the head
      Good Compression
      Here are the readings:
      Pickup Coil 519 Ohms (range 459-561)
      Charging Coil 266 Ohms (range 270-330)
      Lighting Coil 0.700 (range 0.702-0.858)
      Spark plug Cap 10.58 Ohms (10kohms
      Ignition Coil Primary Coil 0.5 ohms (range 0.18-0.28 ohms)
      Ignition Coil Secondary Coil 8.20 kOhms (range 6.32-9.48 kOhms)
      Would y'all think stator and pick up coil, rectifier or CDI are the culprit?
