By Vlaco
Hi. I just joined the community. I have a sheep farm and use a Polaris 500HO, Polaris 700efi and a JD Gator 825i for different jobs around the farm. I do all the repairs myself so I am sometimes needing some advice and maybe I can be of some help to others as well.
By qcm413
Hi,
Thanks for a newbie on this site !
i have grinding noise in my front differential. the front right wheel is turning and the left is try to turn but no movement and make sound like a gear broken. somebody have any idea ? not enough oil in diff ?
thank
By Joeguy
I been working on this thing for like 2 months now and it will not run right, is very smokey, and has a pretty loud tap that i think is in the bottom end. Not sure how much the parts are but i will put the time into it if they are pretty cheap. Im not very experienced but going off how the plug looks and the oil on top of the piston i am getting a whole lot of oil coming in from somewhere, not sure if it can come from the valves or if the rings are just shot, my cheap scope cant really see the walls of the cylinder too well.
20241009_123850.mp4 -
By DGBear
My front brakes started dragging and the lever travel was minimal. I bled them and topped off the fluid reservoir and they worked great for a while and now the problem has returned. I'm thinking that a piston may be sticking. Any thoughts on this problem?
