hi im steve from ny and new to site i just bought a 2005 brute 750.with a 820 kit cames ported head dyna ignition 28 silver backs on it. 40 miles since the engine build with a totle of 810 miles it smokes after i do a few wheelies then if driven awile with no wheelies it stopes smokin is that a v twin thing oil level isint to high anyone have this problem other then me thanx steve
Edited by Ajmboy
Welcome to QUADCRAZY!
Its just something the V-twin motor does I believe when pushing for more power. Also, doing wheelies causes oil to go where it necessarily shouldn't and into the combustion chamber.
Make sure your oil is not over filled. Make sure there is no oil in the air box, that motor pushes oil into the air box from what I heard.
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
    • By JMSwed
      Hi EVERYONE
      New member here
    • By Ethan7387
    • By colin james
      View File 2005 Polaris Phoenix 200 service manual
      This is the service manual  for the polaris phoenix 200 down load all chapters to have completed manual
      Submitter colin james Submitted 07/19/2018 Category Polaris ATV
