I have a 04 660 raptor. I love the machine in fields, gravel roads, and jumps. I do not like it in the woods because it does not know low rpm riding. I have to ride the clutch a ton in the woods (especially on slow riding trails)
Does the 700 fuel ejection run better in low rpm in the woods?????
i do not own a 700 but i had a 03 660 and loved it i had the same problem with mine i went up one tooth on my front sprocket witch let me use 1st a lot more on tight trails
with stock gearing 1st was useless but on tight trails 2nd was lugging to much anyway it was a cheap fix for my riding style and if 1 tooth in the front doesnt work for you just go down 1or2 in the back as for clutching a lot learn to love that clutch it will make you faster well it did for me i had a banshee befor my raptor and had to use that cluth all the time and i found riding my raptor or any other quad i ride use that clutch like you are riding a 2stoke just always helps !!!!!!!!!!!!!
That's funny you should say that, IMO a Raptor is one of the easiest bikes to ride at low rpm. You wont find a sport bike with more torque. If you think you have to clutch alot with a Raptor, try riding a 450, I can't lug my LTR at all. I even have to clutch more on my TRX500R than a Raptor, and a CR500 motor has tons of torque. If you don't like using a clutch maybe you would like a KFX 700 better. Or like Havok said, adjust your gearing. A tooth up will make 1st gear more usable, or a tooth down will let you use 2nd gear sooner, but 1st would probably be useless unless you want to pull some stumps. Front sprocket adjustments make a big difference, rear sprocket changes let you fine tune things.
    • By DPDISXR4Ti
      Thanks...
    • By DZL1
      Thanks in advance.
    • By Dsluder
