By DaleJAM
By Gwbarm
Just aquired this Honda 4514. I had heard of them and seen them but had never really looked at one. Amazing machine from the 90s.
It has a 14 HP inline 2 cylinder engine. A cute little fan like the old school cars had and a little radiator. It has a timing belt on the back of the engine running the cam and a water pump. Just like a miniature car engine with electronic clutches to turn blades on and off. Pretty hight tech for the 90s not a small thing and built like a tank weighs in at 600 pds hydrostatic trans. I have found out that almost anything you have to do to it the engine has to come out starter timing belt water pump. Very expensive parts i think most got junked for that reason, i did find out they were built by John Deere except for the honda engine.
Does anyone here have any expierience with these.
By mattgoodwin
I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
