Yeah,,,,,Tigers are Cool....but not the Holy Grail.....The Fabled Factory Honda ATC500R IS the Holy Grail.....There have been Rumors for years that Honda Still has them and some Factory Riders have been Sworn to Secrecy......
I know people with the Tiger 250 and 500....I have Video somewhere of a just Restored one going over backwards on the Drag Strip at Haspin Acres....:aargh: Problem is....There are no parts to be had for them....Unless you have a Stable of them...
thats not that special, you can find a cr500 and swap it, a tiger was a brand all its own, except their 80 that made 23 HP! that motor was from a KTM. they are super rare.
Anybody can make a hybrid. A factory 500cc!?
tiger 500 was a factory 500cc two stroke trike.
tiger made a 500, 250, 200, 125, and an 80.
and they made a quad.
very rare machines.
Rare Machines indeed,,,,But Big ol P.O.S's!!!! The Tigers were Strickly Racers....They were not built for the public to buy...They were built to beat The Big Three at their own game......By the way.....they never we able to beat them...
Dont get me wrong...I respect what they tried to Achieve....I think they are a Cool Animal....
    • By Frank Angerano
    • By Tinkeringreg
    • By USRaider
      Hello all!
    • By tin
      The AMA U.S. ATV Motocross Team of Bryce Ford, Joel Hetrick and Brandon Hoag dominated in the Czech Republic at the 2024 Federation Internationale de Motocyclisme (FIM) Quadcross of Nations. It marks the sixth time that the team has secured a global championship since 2017.View the full article
