Air Filter Maintenance
Your air filter is the first line of defense against the elements. Keep it clean or spend some green. We show you how.The condition of your air filter directly affects the performance of your ATV. The dirtier the filter, the more it robs horsepower from your motor. Running a dirty filter also greatly increases the risk of sucking dirt and debris into your motor's internals which can cause a number of problems in your fuel-delivery system and greatly increase the wear and tear on your piston rings, cylinder and valves. Once again, this eats away at even more horsepower in the long run. The best practice is to clean your filter often and well. How often? We suggest cleaning your filter after every weekend of riding, and even swapping out a clean filter for every day of riding if the conditions are extremely dusty. If you wait for your filter to look like a dirt clod, it'll be too late. So how do you clean it well? Follow these steps and we'll get your air cleaner well, cleaner.
Photo Gallery: Air Filter Maintenance - ATV Rider Magazine
Read More | Digg It | Add to del.icio.us
More...
index.html
    • By Panupong Pradchaphet
