oh man, I just ate! you should warn people about this stuff.
:wink:
is that a THONG? [gagging sound goes here]
DrtyGrl you better keep an eye on that boy, I think he's stepped over the edge!
Edited by Raptor8
:wink:
It is not suppose to be a thong, it's actually sweat pants! Her arse is eatting them.
    • By Werewolf
      Oil is getting in the air box from crankcase vent tube, I put the two hoses that go to the air box together then something started to smoke on the front of the engine. There is a filter? In the line I blew that out.
    • By RiverRoad
      I need a wiring diagram pertaining  my polaris 1999 335 sportsman
    • By Params_sweden
      Hi, my KLF300 Bayou 1994 from my other post can now ignite and run for a little while. It's running very rough, the idle is way off, I have to use both choke and gas to get it in a somewhat "idle" state otherwise it dies. Let's fix it
      I think that the first priority is to get the idle stable, right now I can't get it to idle at all, it's either too high or too low and dying off after a few seconds. The setting of the idle screw doesn't seem to stabilize it, it's either too low or too high, if I get it between those states it's only running for a few seconds before dying. The ATV could idle and run last summer btw.
      What do you think I should do next?
      / Pär
    • By Saskatchewaner
      Does anyone have any experience in converting a Honda ATC to 2 wheels? I've seen them called fat cat conversions or Honda hippos and they look like they could be a blast. I've got an atc 185 that I stole the (pretty much brand new aftermarket) rear end out of to put on a worn out 200m. Looking for opinions on mounting the rear end, if a mono-shock or two outside mounted shocks or no shocks at all. Or if anyone has ridden one and has an opinion if it's even worth doing?
      Thank you
