We have bent so many tie rods on the prowler we started carrying spear ones ,,:aargh:,, we have 4 650 prowlers ,,, but I have come up with a way to fix them, ,,, I took a piece of pipe and bored it out on one end to fit threaded end and other to fit tie rod and welded them to the nut ,, I have several extra ones made up if any one is interested ,,,, it beats walking 20 miles back to the truck [email protected]
  • 4 months later...
I myself love to fab stuff myself but a local aftermarket company makes Arctic Cat Heavy Duty Tie Rods which are made from 3/4" SCH. 80 pipe and utilize 1/2" chromoly hiem joints. Nothing special about the pipe but the hiem joints are a great idea.
    • By Eisaks777
    • By marcosphoto
    • By Coyote251
    • By Chucksta
      Any ideas?
    • By mga
      I just saw a video on TikTok where some guy took the rear end off an ATV and bolted on a roto tiller in place of rear wheels. I wish i saved that video to post here....good thing it was 4 wheel drive...lol but, it seemed to work.
      I'm not sure how he made it bolt on to the drive....
