    • By onequad
      i got a 93 400 Kodiak the frame on one side is rusted out.  is this a comin thing? was wondering if it worth the  tumble to put in a used one. I'm worried most of the bolts will brake. it don't look the rusted over all. just the part were the frame boke in half. do all kodiaks have the same frame
    • By BenJammin
      I did a compression test on my 2005 Bombardier Traxter 650 CVT and it's 75 PSI.  service manual only talks about leak down test.  No specification for engine compression the manual.  What does 75 PSI tell me?  Thank in advance.
      A little history of this machine.  640 miles.  Picked it up about 2 years ago, not running. Probably the computer.  Tested all circuits and confirm it was the computer.  Long story short, I watched a Youtube video and fixed the computer. ATV now started and runs.  BUT, it tops out 20 MPH.  I cleaned the carb 3 times also using a Mikuni carb kit after the second time.  Slide in carb is going up and down.  Only adjustment for fuel is at 1.5 turns out.  NGK Sparkplug had soot on main part but brown on the electrode.  Champion sparkplug is brown.  I check CVT clutches and they both appear to engage like they suppose to.  Checked valve clearance it's 0.00, I can't get any feeler gauges in-between.  I check timing chain I believe it's in the correct position and hasn't skipped.  I removed muffler plug and drilled into muffler to try and make sure it wasn't plugged.
    • By joshua91673
      hi every one .anyone out there my issue is my kick start wont stay out  i have to have some one pull it out.  it pull out easy just wont stay out to kick it over .kicks over and starts no problem
      also does this quad have a ajust mint for the rear spring .it sags when i get on it .or is this normal . thanks guys for your time
      first post
      josh ohio
    • By Jhb12686
      Hello I appreciate the welcome into the group. I am beyond frustrated with this desperate search for parts. I have a 2013 XY power sports UTV 300. I had a catastrophic failure in my rear differential which resulted in the destruction of almost everything inside. I have located everything I need to completely redo the rear end. But I cannot find a short side axle shaft with six splines etc. it's an offset differential and one shaft is longer than the other and I need the short one. The tip of it broke off (pic). Any help in getting another shaft for this thing would be GREATLY appreciated. Thanks guys
    • By n4cer26
      Just bought a non-running 425 Magnum 6x6. Guy said previous owner had motor rebuilt (3 years ago or so.) It reportedly ran great but recently the electric start began failing and he put a new recoil on it which he broke immediately.
      I get it home and put a new recoil on it and the pull is incredibly hard....so much so that I think I'm going to break the new recoil assembly. I also installed a new starter which won't roll it over either.
      I'm thinking maybe a hydro-locked situation so I pull the plug and the motor rolls over fine with both pull start and electric start. The cylinder was dry however.
      Checked the valve lash and it was right on at .0006".
      Checked the compression relief spring on the end of the cam and the spring was strong and keeps the metal piece against the dowel like it should. The cam lobes look good from what I can see.
      I have a small camera that I dropped into the cylinder. Could t get a pic of the entire chamber because of the angled engine but there are marks on the center piston and a couple of grooves once side of the piston top. I will include the photo.
      Anyway....I'm at a total loss at this point. Not sure how to proceed and diagnose. Would sure appreciate anyone's help who might know what the heck is going on! I was able to get it to turn over about 5 times with electric start with compression tester installed which read 145 lbs. I don't know what else to do!
       Reply
      Sent from my SM-F926U using Tapatalk
