Oil Change - Yamaha Rhino
Oil change steps for the Yamaha RhinoBefore you start, you'll want to make sure you even need to change the oil. Do you have a brand-new Rhino? If so, you should change your oil after the first 20 hours/1 month/200 miles, whichever comes first. This is important in the initial break-in of your motor. After that, the manual says you should drain the oil every 150 hours/6 months/1500 miles. However, most industry professionals will tell you this is way too long and suggest changing the oil every 75 hours/3 months/750 miles and swapping out the filter each time. The problem is that the manufacturer is assuming you're using your Rhino for nice quiet drives on a graded dirt road...yeah right, most of us are barreling through mud holes or screaming up dunes for hours on end. Plus, your Rhino basically has the same motor as a normal ATV but is doing twice the work, hauling around an additional 400 pounds and a passenger. That extra stress needs to be taken into account when deciding how often to change your oil. This also applies to any performance modifications you've made. If you're putting extra horsepower through the engine's internals, you'll want to change the oil more often to help prevent premature failure.
Photo Gallery: Oil Change - Yamaha Rhino - ATV Rider Magazine
Read More | Digg It | Add to del.icio.us
More...
index.html
    • By Frank Angerano
    • By Tinkeringreg
