By kawasig
By Trent Finnessey
So I’ve got a 2000 Honda 400ex absolutely love it!! I’ve had it for about a month, I ride with bruteforce 750’s, outlander 850’s and 1000 sxs’s and I was thinking of getting a trx450r carb and a full hmf exhaust. And probably doing the air box mod too, how much power would this give my 400? Just a little different or a big difference? Cuz if it’s not much of a different I’ll just stick with my dg slip on..... thanks!
By gt_jacket
Hi,
I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in. Neutral and Reverse lights work.
But when trying to start in neutral, there is no click or attempt to start with the push button.
However if i pull up on the shifter (not hard enough to shift into first though) the neutral light goes off and the start button works and it starts fine.
All gears shift fine with no issues, has anyone seen this before? Just wondering if it is a bad sensor or something needs adjusting.
Thanks for any help you can provide.
By DaleJAM
