I didn't know they have a baby brother of the Rhino 660!
MSRP* $7,999 (Hunter Green) Available from October 2006
$7,999 (Red) Available from October 2006
$8,449 Hunter (Hardwoods HD Camo) Available from October 2006
Engine
Type 421cc liquid-/oil-cooled w/fan, SOHC four-stroke single
Bore x Stroke 84.5mm x 75mm
Compression Ratio 10:1
Carburetion Mikuni 33mm BSR
Ignition DC – CDI
Starting System Electric
Transmission Yamaha Ultramatic® V-Belt/H, L, N, R
Engine Braking All Wheel
Drive Train Yamaha On-Command® push button 3-way locking differential, 2WD, 4WD, locked 4WD; Shaft
Chassis
Suspension/Front Independent double wishbone, 7.3” travel w/5-way preload adjustment
Suspension/Rear Independent double wishbone, 7.3” travel w/5-way preload adjustment
Brakes/Front Dual hydraulic disc, twin pistons
Brakes/Rear Hydraulic disc, self-adjusting, shaft mounted
Tires/Front AT25x8-12 NHS
Tires/Rear AT25x10-12 NHS
Dimensions
L x W x H 113.6” x 54.5” x 73.0”
Wheelbase 75.2”
Turning Radius 153.5”
Ground Clearance 12.1"
Fuel Capacity 7.9 gal.
Dry Weight 1038 lb.
Bed Capacity 400 lb.
Towing Capacity 1212 lb.
Other
DC Outlet Standard
Instrumentation Fuel sight gauge, 4WD indicator lights
Lighting Dual 30W Krypton multireflector headlights & dual 21/5W brake light
Warranty 6 Month (Limited Factory Warranty)
More info at http://www.yamaha-motor.com/outdoor/products/modelspecs/441/0/specs.aspx
    • By Coyote251
    • By Panupong Pradchaphet
