I had a quick look at some parts diagrams and it doesn't appear to have a clutch. The three models I looked at were all belt drive. I also have the 2008 750 manual so looked in there and it looked like the same engine/trans setup, and it has no clutch. It seems the belt and pulleys are the only "clutch"..
I would suspect that the variable ratio system of the belt drive is playing up. That's the variable width belt pulleys I'm talking about. One of them is possibly moving apart at too lower revs, or one of them isn't moving apart when it should.
He should get a manual. They can be downloaded for free, from right here in quadcrazy quite likely..
It sounds like the drive (primary) clutch is getting hung up somehow and can't move properly. I've seen bits from a broken belt get into the sliding sheave bushing making this happen. You'd likely need the proper clutch puller to get it off to clean & inspect.
    • By carkivey3
    • By mmikesell
    • By EasyE
    • By opnea
      Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
