  • Admin changed the title to Need help! 1987 Yamaha Moto 4 350
I would probably check the pickup coil for proper resistance and that it is putting out voltage first, the value should be listed in your repair manual. If you dont have a manual you should try to get one. Is your new CDI aftermarket, sometimes they dont work right out of the box, if the original CDI is OEM dont throw it away until you are sure thats the problem.
Yup. What Gw said, and check the resistances right at the cdi also to make sure the wires are intact. Check them down at the engine then again at the cdi and compare the figures..
    • By Arizona
    • By KSIM
      View File 2018 CF-MOTO Z-Force CF1000US-2 service manual
      CF-MOTO Z-Force (CF1000US-2) (2018) service manual
      Submitter KSIM Submitted 03/19/2025 Category Other Brands UTV
    • By Kawasakibayounospark
    • By DPDISXR4Ti
      Thanks...
    • By carkivey3
