There were some CPI ATVs produced around 2007 one that comes to mind is the CPI XS250, but that engine looks smaller than a 250. There were also some CPI scooters made around the same time may still be around but i have not seen one.
    • By carkivey3
    • By mmikesell
    • By EasyE
    • By opnea
      Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
