I have a 2019 400FSi , and the neutral light began blinking on/off sometimes.
Now the light stays off and I pretty sure it's a neutral safety switch, if there is one on this bike.
Where is it?
Can I bypass it to check if it is it?
I would need to order a part, I'm in remote part of Alaska, can someone tell me what the part is called? Can not find it searching online.
I jumped a wire across neutral relay and bike turns over but will not start.
I jumped starter solenoid, and bike turns over and will not start.
Bike is in neutral.
Thanks for any help
Have you checked it's got a spark at the plug ?
If you try to start it, then pull the spark plug, is it wet with fuel ?
Are you sure the fuel is fresh ?
Does it have compression ? When the plug's out, can you keep your finger sealed in the hole while you use the starter ?
    • By carkivey3
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
    • By jwh
    • By mans
      Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
