   I plan on working on it this weekend and would just like some opinions or feedback from anyone who may have experienced these problems before. I'm very mechanically inclined but im unsure of exactly where to start as this is the first Polaris ATV that I've owned. Any feedback is appreciated and thanks in advance :)
Yup definitely check the shift adjustments.
It's strange it cuts out when it jumps out of gear. That might come right if the adjustment keeps it in gear. If the adjustment doesn't cure the jumping out problem and the gearbox needs work, then I'd try to figure what was causing the cutting out before I fixed the gears.
If, after adjusting the shift so it's moving fully into high, it still has he problem, it would be a good idea to take careful note of what the circumstances are causing it to jump out. There are some tests/observations to be made before stripping the gearbox.
On 1/4/2025 at 1:06 AM, Gwbarm said:
I think the first thing i would check would be the shift linkage make sure its well oiled and moves freely it  could possibly need adjustment.
Ok, so I stripped it down this weekend in the garage and found some issues.
Number one was the gear selector itself,  I took that apart, and it was an absolute nightmare of rusty water, mud, and anything else you could imagine. I cleaned it out along with all of its small internals and put in new ATF fluid for the lubricant. It now moves freely and shifts smoothly. Time will tell if the internals will need to be replaced but as of right now, it's ok.
Number two is the linkages that connect the selector to the transmission. The long one for both HI and Reverse had a considerable amount of washers on the end where the nut meets the tie rod. After loosening the nut and moving it back, I discovered that the washers were there because someone had stripped the threads on the rod. Due to this, I can't tighten the nut and properly adjust the rod. This makes sense as to why the shifter would occasionally pop out of high gear because it's not properly adjusted. I also discovered that the rod for the LOW gear is welded at the nut and the end rod. So I'm now either on the hunt for new/used linkages, or I may be able to re-thread the end of the rod.
Number three is that my driven clutch appears to be out of alignment. In neutral and at idle, the belt is sticking to the sheeve and constantly turning itself and the driven clutch. Due to this, I've ordered a real belt (Chinese one on it right now) and a package of shims to align the driven clutch properly.
Still unsure of why it was dying in gear that time because it hasn't happened since however I'm assuming some combination of improper adjustment of both the shift linkages and the driven clutch was the reason.
As I said this is the first Polaris ATV I've owned, and I'm new to the whole CVT transmission. Although it's a pain, it's still been a fun experience learning about these mechanisms.
Glad it wasnt internal. You have been busy. Good diagnosis. It sounds like it has been ridden hard and jammed in and out of gear many times at some point in its life. I think it is repairable clean up the threads on the rod and it may work, but i would be tempted to look for a new shifter in good shape, you definately want to get it adjusted correctly so no internal damage happens. Hopefully the correct belt will solve your clutch problems also.
"Still unsure of why it was dying in gear that time because it hasn't happened since however I'm assuming some combination of improper adjustment of both the shift linkages and the driven clutch was the reason. ".
The only think I could think of that would make it stall when it jumped out of high, was if it jumped into reverse. That would try to stall the engine if you were moving forwards at the time, but it shouldn't do it when you had just shifted and not got going, which I think was what you'd said it did sometimes, jumped out from an attempted start, but.. That , going into reverse, might stall the engine if the belt was driving as you are saying it does..  You'd think you'd have heard a clunk though if it was jumping into reverse.. So I assume it's not the case.. My best shot though.
Ok so I figured I would follow up and let you guys know what’s been going on. I’ve definitely been getting busy with the ole quad. I ended up replacing the shift rods because they were both to far gone. Along with that I put on a new belt and a new clutch on it. With both of those working properly I no longer have had any issues with it jumping out of gear into neutral. Since the day it wanted to died on me it hasn’t happened since and everything has been running right.
I bought the quad off of an older gentleman so I think at the end of his ownership maintenance had been neglected which is totally understandable due to his age. After I did the rod and clutch work I’ve also replaced tie rods, brake pads, the starter, fuel filter, pull starter and I popped off the fly wheel and cleaned that entire area because it was full of rusty water. So far it’s been running great and starting no problem even in the cold weather.
Although as you could imagine some of the work has been greasy and a bit of a pain I’ve definitely enjoyed learning and working on this Polaris machine. As I said I figured I’d follow up with you guys and let you know what was going on. Along with that I wanted to say thank you for your suggestions and tips about what could be the problem with it. Cheers guys, thanks again!
    • By Tim Keiper
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Frank Angerano
