Weird because there was two marks on the flywheel and they were on opposite sides, the one put it to had a capital t and a line the one it was at before was just a regular line, but anyway everything else is good I got an oem carb needle so maybe that will fix it if not I’m gonna sell it as is with a box of parts
Ok so it’s being weird last night I messed with it I pulled the carb and cleaned it and replaced the plug and needle and it ran like a dream and it went full speed and it had a lot of power so o had a buddy of mine come and check it out so he gets on it and it goes right back to running like crap so I don’t know what’s going on, did dirt or something somehow get in the carb that fast? Is the choke sticking or something?
to clarify my buddy came and looked at it about 40 minutes after it was going good so I don’t know what happened I’m lost
Key or kill switch has dirty contacts/lost movement ?
You would I presume have used one of the switches to turn it off between your ride, and the buddy arriving.
But it was the key switch you used..  That's the one that would logically have the problem.. You should/could try bridging the key switch with a small jumper wire.
Ok so o haven’t messed with the switch yet but I looked at the spark plug and it was wet so I had an extra one so I put the new one In and it rode great, but about 2 minutes in it started riding badly again so I took out the plug and the new one was wet so is it flooding somehow while I’m riding? Float maybe?
I will check the switch though just to make sure that it’s good
You are going around in circles here NHWQ. It's really really important you work through your possible faults eliminating them one at a time by doing a really thorough job and making sure that one thing at a time is right. Just looking at things and deciding they look fine isn't enough, you have to know they are fully functioning and correct.
By now your carb should be clean and set up right. The only thing that should possibly alter/go wrong in the carb is the fuel level if the float needle or seat is defective, has dirt getting to it, or is leaking under the seat. Those problems, which do occasionally happen temporarily, can generally be cured by turning the fuel tap off for a while.
Try turning the fuel tap off and start riding, when it starts running out of fuel turn the tap back on and keep riding. Check whether it goes better as the fuel runs out in the carb, or when the tap is on. Do it repeatedly till you are familiar with how it runs at all speeds, loads and throttle openings both with a full carb, and as the fuel level drops/is low. That way you will diagnose whether it's a fuel problem, and you will hopefully become familiar with the symptoms of low or enough fuel, or if it turns out it is flooding, what a flooding carb does.
Switches can get no or dirty contact because of dirty contacts, or they can have wear that gives them lost movement, so when you move the key or button they don't slide the contacts far enough to turn right on or right off. In the case of the kill switch it could have rust in it that could be enough to partially short out and give bad running. Dirty contacts can generally be found using an ohms meter, but for the key switch it's better to do a "voltage drop test"..Google voltage drop test. Make sure you understand how a voltage drop test works, and how that relates to a key switch.
Ok so I tried my best with what I could find, so on the ignition switch I tested the negative side and the positive side, the negate read .6 something and the positive read .8 something and this was when I cranked the engine, I will send a picture of where I connected the probes to make sure I did it right
The middle left wire is the negative and the middle right is the positive, first I connected the negative probe and then I connected the positive probe to the far left, which should be the signal that lets it crank and then I swapped it with the positive to test that, is that the right way to test it? Also when I cracked it I hit record on the multi meter and that’s how I got those readings they were the max
You should have 12 volts on the red wire going to the keyswitch, when you turn the keyswitch on voltage goes to the start button when you press the button sends voltage to the starter to rotate the engine. If it is starting you do have voltage or it wouldnt start. Not sure what the .6 and .8 is, do you mean less than 1 volt. But from the looks of the switch you either need to dig deeper and clean up the contacts or replace the switch.
#107, Not sure about those figures. They might be ok. But unless the starter works by turning the key against a spring for start, then I think you've misunderstood the wiring diagrams.
Try using the ohm gauge and check which contact/wire gets connected to which other wire on the back of the switch's plug, and then check that when they are connected they have less that one ohm resistance. I think you'll find there are two wires that get connected when the key is on, and disconnected when the key is off, and another pair of wires that are connected when the key is off, and disconnected when the key is on.
You need to read up on "voltage drop test". Some polaris manuals have a good description and explanation. The web also has it.
Then you need to find where the bad connection is that's causing the voltage to drop when a load comes on it.
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Frank Angerano
