It's likely that the rings are riding on a layer of oil after the oiled comp test. To get rid of the smoke you need to ride it putting the engine under a load at medium revs. Going slowly up a long hill should do it.   Then...
There is a way to test the oil rings. You get the engine warm and then in neutral you start gently revving the engine to about 1/4 revs and letting the throttle off as soon as it gets to the revs. You just keep doing that non stop, with the throttle open a bit less than 1/4 open and until it gets to about 1/4 revs, then you snap the throttle closed, as soon as the revs get down near idle, but without waiting for it to idle, you open the throttle again. You might need to experiment a little to get the amount of throttle right, and the revs right, but if the oil rings are bad it will start blowing huge amounts of smoke, and the smoke will get worse the longer you keep doing it. It doesn't need much throttle and it doesn't need much revs. My 1/4's may be more than actually needed. Once you get it right, it will make even slightly worn oil rings smoke bad. I've bought cheap machinery by doing it I'm ashamed now to say..  haha.
If the smoke doesn't come, or if it's only a little smoke and not a steady stream of smoke, then it's more likely to be your valve guides that are smoking.
Ok so I took off the top end and obviously I’m getting rings but the cylinder walls had a bit of light wear with up and down scratching(I don’t remember what the real term for it is) so I’ll hone the cylinder and put new rings in also the piston was a tiny bit loose in the cylinder but when I looked at the piston the thing looked brand new in terms of wear on the side, there was a bit of gunk on it but there wasn’t and wear on the sides so should I get a piston too? I’m gonna try rings on the original piston first but if that doesn’t solve it should I try a new piston?
I would put the rings one at a time in the cylinder and Mic the ring end gap to see how badly they are worn, should be around .019 i would also Mic the cylinder and piston to see if it is within specs if not get a new piston. If the cylinder has scratches the piston should have matching scratches unless they are from a previous rebuild job.
If the scratches will hone out they will be ok.
If there is a lip/ridge at the top of the bore, about where the top ring gets to, then you need to remove the lip/ridge or it will hit a new ring and break it. You will be able to feel a lip if you run your finger up the bore front and rear. You should really measure or calculate how much taper there is causing that lip. Too much taper makes the new rings work harder and shortens their life.
You should also check the side ply between the new ring and it's groove in the piston.  That's the clearance above or below the ring. Too much side play lets oil past, and eventually breaks rings.
You should fit new valve guide seals also to be sure to stop the smoke.
The exhaust is likely to be full of oil too.. You should run it at moderate revs but with a decent load on it(up a long slope), that will seat the rings in. Get it good and hot and see if the smoke doesn't start decreasing aft6er an hour, or, take the exhaust off and go for a putt.
The bad idle might be the mixture needing adjusting, or the valves might have adjusted themselves after the first start and might need readjusting. Try not to let it sit idling though, that can bugger up the rings seating and give a less than satisfactory ring seal that's hard to cure. Ride it with a load on ..
Alright so you were right about there being oil in the exhaust it doesn’t smoke unless I hit really high rpm’s and even then it’s just a little bit which might just be a little left in the exhaust but the stupid thing won’t idle at all I tried messing with the carb and adjusting everything and I even had the idle set all the way up and yet the idle didn’t go up and it still wouldn’t idle but other than that it runs ok
Oh and it pops a lot almost like a backfire and it does it even at the slightest of throttle
And to respond about the ring gap it was good also I don’t remember exactly what it was but the gap was good also I readjusted the valves and you were right about that as well
Well the no idle and backfiring could be dirt in the carb or an air leak at the manifold, or a carb breather pipe on the wrong place or blocked. Those are the most likely.  I think I'd just pull the carb off, check the manifold for cracks, then clean the carb and put it back on knowing that part was all right. You need to clean the carb thoroughly though, and check the float level etc, so you do know it's right..
I could look up the original carb's jet sizes, but an aftermarket carb might have a different emulsion tube, and/or needle, and might need different main jet, and/or main air jet..  That's the trouble with after-market, if they aren't the same design, then the jetting is just guess work.
You should try changing the slide needle setting..
Alright so I check the manifold and it was good so I dug into the carb and I cleaned it good it was already pretty clean but then I brought the needle up and it finally idles I didn’t even think about the needle so now it’s running and idling really good I will take it for test drive soon and make sure that there’s no overheating or anything
Alright so I think it’s running pretty good I’ve just got to mess with carb adjustments I think but one thing is that I can’t push start it for some reason, I’ll kick it into first and the thing just rolls like it’s in neutral and that’s for every gear, any idea what that could be? Not really that interested in fixing that but just wondering what it could be
Edited by Need-help-with-quads
The sprag/oneway clutch in the centrifugal clutch isn't working. You'll have no engine braking once the engine revs get low enough for the centrifugal clutch to disengage.
When you were testing it before you must have have not let the bike get slow enough down hill for it to do it, but if you go down a steep slope in gear and leave the throttle off till the bike's almost come to a stop, it'll accelerate and start rolling away again uncontrolled once the centrifugal clutch disengages.
If we know the bikes got the fault and take precautions when going slow and don't rely entirely on the engine braking it's not too dangerous, but people that haven't known their bike had the fault, have been hurt or given a scare  when their bike having almost stopped, then started rolling and rolled off a bend or into a gate..
Ok I finally test rode it good and found that it runs great at low rpm’s but then I get to 1/2 to full throttle and it pops and sputters so much that I can’t hardly pick up speed, I didn’t pick up on that the first time I test rode it because I only had time to putt around the yard so I tried all the settings on the needle and nothing worked so I tried the mixture screw and I couldn’t get it to work, so I ordered an oem needle because the one that’s in the carb is a cheap rebuild needle all the jets and everything is oem so I’m hoping it’s the needle but that said, anything else I should look for?
Depends where the "pop' is  coming from. If it's under load and out the exhaust it may may an electrical misfire. If it's out the carb then it's probably a lean mixture.
But...  the no idle and popping could be caused by valve clearance or valve timing.
You really have to know one part of the system is absolutely right before you start looking at the next possibility. Valve clearance and timing is simple and doesn't take any discrimination or experience to judge. A new spark plug is simple and cheap to replace. The carb, which is from the sound of the description (symptoms and circumstances), the most likely, needs to be right for that bike. If the carb's been set up to be mounted flat it may not run well on a bike where it's mounted at an angle. You need to use some discretion when checking the jets and settings. If the float level's set different by the manufacturers because it's for another model bike, then the jets may all be suited to that float level. I always check the float level seems right for the way it's being mounted, then ride it taking careful note of all the symptoms and the circumstances they occur under trying to figure what part needs adjusting or changing.  I only ever change one thing then go for another ride taking careful note of what effect that had to the fault, and whether it's made other ranges of throttle better or worse. The three jet systems in the carb, idle, mid-range and full throttle, all overlap, and there are special features that help with the transition from one system to the next. The usual way to set a carb up is, get it idling and running, test ride and set the main jet system, then recheck the idling system, then set the mid-range system. Sometimes we have to go around the cycle doing all three again if it was a really badly chosen or set up carb. It takes time, a lot of careful test riding, and a good understanding of what's going on..  That's why it's always best to stick with the original carb
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Frank Angerano
