On 9/28/2024 at 1:14 PM, Gwbarm said:
It should have them if the brake light switch is working, sometimes they get corroded badly and need cleaning. What problems are you having.
No problem, I  just noticed the blue wires with nothing plugged into them. Sounds like their for brake lights. Thanks everyone for the replies.
  • 5 months later...
Working on multiple electrical issues on my 1990--no push start, headlights and taillights don't work.  New battery, new starter solenoid.  Have a new starter relay coming today.  Can jump start from the solenoid, but not from the 2 black wires going to the relay.  Any ideas?
    • By Brad1968
      I purchased a '87 Moto 225. It didn't run. After getting it running, I was surprised it smoked like a smoke stack because it was rather quick. I'm guessing it's the head gasket.
      Has anyone had a smoking problem?
    • By mattgoodwin
      I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
    • By Derek4518511
      Mid 80's 340 artic cat is going into a go cart just for fun i bought a new cdi unit the original plug was cut off when I got it. there is 5 wires 2 yellow, a red a white and a brown my new cdi has 5 also a  lt/green a blk/wht abrwn, a black a blu/grn is there a wiring diagram I can use for reference or which wires go where a y help would be greatly appreciated jated.  BTY I'm  Derek and new to this forum I am actually trying to help a friend with project and learn a little in the process
    • By Uglyside38
      Has anyone had any luck converting an older quad from a 7 wire CDI to the newer (and cheaper) 5 wire CDI?
      I have a 1988 Suzuki Quadrunner and I believe the CDI is on it's way out...🤦🏼‍♂️ A used CDI from 1988 goes for $250-$300 on the bay...and that's when you find them. The Chinese CDIs for the 1990 and up quadrunner are only about $40. I have read a blog from a guy who says it's possible and that 2 of the wires can be omitted if the rectifier is a newer one also. Any experience with this would be greatly appreciated!!!🤙
    • By allonmorris
      Hey guys,
      I have a 2002 yamaha wolverine that needs a new wire harness.  Does anyone have a clue where i can get one new or used. ive looked all over and cant find much on a 2002 model.
      Any help will be greatly appreciated.
      Thanks in advance!!!
