1992 kawasaki bayou 300 KLF300-B5 repairs
By Gwbarm
By semicolon
By NZrider
My king quad 700 runs rough when cold then won't start some times but not often when it's hot. And occasionally smoke's a lot when it's cold I'm guessing that's rings but I'm worried unless it's causing the other problems
All help is appreciated thanks
By bighoss
i got my son new outlaw 50 a few weeks ago and we went rideing yesterday and while we were riding it died and it took me like 10 min to get started back and it died agen when we got close to truck so i pulled it back took the plug out it looked like it was drop in a bucket of gas took the air filter out and the ait box was full of gas also got home it started rite up today i started it it starter up but was blowing what look like water out of the exholst let it idel for a lil bit did not die but as soon as hit the gas and let off it will die what does that sound like i thnk i going to take it back to dealer and tell them to fix it as it is under warrenty but would like to know what it could be first
By N00bie
