Hey guys,
Any chance on someone has already change the tyres for diferent sizes for the 850XC?
I have 1.5 lift, Clutch kit / Variator upgrade (STAGE 1) CFMOTO CFORCE 850 and spacers.
Will 28'' or 29'' tyres are fine to put?
That sounds reasonable, for every inch of extra tire height you get about 1/2 inch more ground clearance, it will be taller which will make the machine easier to roll, but since you have installed the lift kit and spacers that should give it a wider footprint and be OK.
