So, I bought the machine almost a year ago and have been chasing problems. I have replaced the battery, starter solenoid, spark plug, and the starter. Since having replaced those, it doesn't want to start. I checked the carb, and it was wet as well as the spark plug. And I've searched multiple forums and cannot find an answer. So, anything that helps is appreciated, thanks.
So you saying it was going before you replaced those parts, but now that you've fitted the parts it won't start ? And you fitted all the parts in one go ?
And what were the problems you've been chasing for the last year ?
It sounds like the no start now must be something you've done if it was going before you fitted new parts..
A wet spark-plug sounds like you have a weak or no spark. Have you checked if there is spark at the plug ?
Have you gone back and checked all the wires you touched, or near where you were working ?
If the bikes been sitting for a long time, has it got fresh fuel ? Stale fuel will make it hard to start and can flood the spark-plug.
    • By Tinkeringreg
    • By Dumass
    • By Trent Finnessey
