I have a 1989 quadrunner LT160. I am looking to replace the plastics. I can't find them for the 89 specifically but I do see plastics for a 91 - 01. Is there a difference in the 89 to the 91 - 01 plastics? From the photos, they appear to be the same with the exception of the holes for the front and rear racks.
Please help clarify if you can. Thanks!
    • By sugrbuzz
      Looking for a service/owners manual PDF
    • By jwh
    • By marcosphoto
    • By Parham
      My old quad needs new tires.  I am having a hard time finding the OEM size 25x10-10.  Anyone running more readily available 25x11-10?  Any issues?
    • By mga
      would the plastic fenders from a 1998 grizzly 600 fit on a 2000 big bear 400?
