1990 Suzuki King Quad 300cc Kicks and bucks when accelerating unless ignition switch is in LIGHT position.
By Tinkeringreg
By kaidella
By TravisM
2001 bayou 220 KLF220A
I'm at a loss here. Thanks.
By mans
Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
By Mmessy83
I recently purchased a complete lt230s for$50. It was missing the kick starter gears which I got off eBay for $18. I’m trying to install the gears which after reading different threads about having it timed. I have it all timed but now it acts like engine is seized up but I know it’s not. What could be going on??? Any insight would greatly be appreciated.
