    • By p5200
      Hello, would this be a good Master Link tool for pressing master link plate back on? I've seen others made of aluminum but thought this one might hold up better. Thanks! 🙂
      https://www.amazon.com/BARTOO-Motorcycle-Convenient-pressing-Alignment/dp/B0C4FB1V7D/ref=sr_1_3?crid=1KRW04WLD82EI&dib=eyJ2IjoiMSJ9.4Y2_vOEctIVv0vgmajSYXL844RphCjGBrMsiewv7Z1sVIMYMM5OQNBL0cXeHLmUDsnKMO5JffQPEP8vl4xuxCUczEfKGgw4r-MYmLgCzydGm9sHnK8hX7o1AqXunVpgpR8RrfQ8noUmfLyoxTqUcrl9tj82jDWeB5CL1rifd--ufsiyaWkBl4omd_1qyx7a97BvOTogpK40NTm9BfKjSt2H5mXrjEnhEOcxSYxUHiRx61KbfDBaA8B9CvwQjM3qGIf4Ay1zWxxPURTnX5qjhddcAADez5JNCFVrUYeLE-7M.sFaeyu09Q7O8v9B0NPjaDYDuHqVqE4uyxspDEpxBs6U&dib_tag=se&keywords=chain+press+tool+for+polaris+500+scrambler&qid=1709916341&refinements=p_85%3A2470955011&rnid=2470954011&rps=1&sprefix=chain+press+tool+for+polaris+500+scrambler%2Caps%2C198&sr=8-3
    • By xtreamclean
      The newest mud/debris release agent from our lab is Mud Guard X2. This concentrate is a new polymer based product that will provide a treated surface with release agents to allow for easier and quicker clean ups. X2 will place a protective coating on the surface to which it is applied and help prevent mud and general debris from sticking hard, allow liquids to sheet off and add protection from the elements for long lasting results. Saves you time and energy to allow for quicker wash-ups and cleaner results. X2 is easily sprayed onto a clean dry machine and wiped to an even film and allowed to air dry. X2 provides a coating that will withstand multiple washings. This product can be usd on any on-road, off-road or on-water machine. X2 is especially effective for dirt track racing of all types. Safe on ALL surfaces. It does not contain any solvents and is non-corrosive, non-toxic and biodegradable. Mix 4 ounces of X2 per quart water or 16 ounces of X2 per gallon water. 32 ounce size of Mud Guard X2 will make over 2 gallons of product. More info Mud Guard X2 Concentrate
    • By xtreamclean
      X-Tream Clean Products based in Charlotte, NC has introduced a new product called Chain Lube Gel Spray (CLG) to its line-up of quality cleaning solutions designed for the powersports industry. X-Tream Clean Chain Lube Gel Spray is unlike many of the chain lube products on the market today. We have combined the attributes of lubrication with lock-on technology into one product that will provide superior lubrication without sling. Chain Lube Gel Spray is a gel bodied product that goes on wet to penetrate all chain surfaces and quickly dries to a clear film. Our high performance PTFE gel lube will penetrate hard to reach areas and then expand to provide long lasting lubrication and rust prevention. Chain Lube Gel Spray remains pliable, will not harden or crack and will resist change due to mechanical working.
      Tired of thick, messy, waxy, dirt and dust attracting chain lubes? Chain Lube Gel Spray is designed to dry to a non-tacky film helping to prevent dirt and dust from building up on your chain while still providing X-Tream lubrication. Product is also easily cleaned when you’re done riding unlike many waxy chain lubes that are a hassle to wash off. Cleaning our non-tacky, non-messy, non-waxy chain lube is X-Treamly easy. Chain Lube Gel Spray repels water and is an excellent rust and corrosion inhibitor. Chain Lube Gel Spray does not contain any CFC’s and is non-corrosive. Safe for all standard and o-ring type chains. California OTC VOC Compliant. Product is packaged in a 13 oz aerosol and retails for $9.95. More info www.mxwash.com.
    • By lawny
      What's everyone think of the news releases Polaris and Arctic Cat just came out with? The RZR with a new 900 power house with a whopping 88 hp's, I'd like to see that engine in a Polaris built mud slinging quad, that would really get my blood pumping! Or Arctic Cat's new entry machine in the sport-4x4 market, a 450 crossover. Not really news, it's just a Kymco in Arctic Cat clothing. Dissapointed they didn't hook up a bigger rubber band to the driveshaft on this one.
