Even if you identify the year and model it's likely you won't be able to get a service manual for it anyway.
The body work will be held on by bolts or clips or a combination of the two, and likely some tags that slot into rubber grommets..
You might find a manufacturers tag somewhere on the frame that says who it was made by, and it might have some numbers indicating the model. The tags are sometimes on the steering head.
    • By oxidized_black
