South Florida.
How much it worth?
Pros: looking decent.
Cons
No brakes.
Front wheel bearings are shot.
Idles, but sometimes will shot off. Most likely when cold.
Gas smell and little bit steam in the air filter box when I started it.
Display screen won't work.
Tires are dry with cracks.
Not sure if has title, I will check and update.
How much do you think it worth?
Thats a hard call, according to JD power the value range is from 1600-2200, but when you see one for sale its between 3000 and 5000 and you dont really know if it actually sold for that, yours looks good, so that is a plus, but has a lot wrong with it. I would estimate if it runs good shifts good, even with the carb problem, you should be able to get ,with everything wrong, between 1200 and 1500. I f you fix everything i think around 3500. Just my opinion from what i see, nobody will pay much more than that for a quad that needs a lot of work.
