My Yamaha Big Bear shifts through all the gears good, goes into reverse smoothly, but when i go to get out of reverse it takes a lot of effort to get it back to first gear, and even then it does not go very smoothly, have to pull up on the pedal really hard, anyone else ever had this problem. Any ideas would be greatly appreciated.
You'd already know the obvious ones.. fast idle or binding between front and rear..
Does it do it if you haven't moved the bike ? Like if you just slip it in and then try to take it out again does it do it ?
Its mostly troublesome  when i pull up to hook on to my trailer i put it in reverse back up hook it up. then cant get it out of reverse, so i have to get off pull the shifter up forcefully with my hand and it will go.Its like i just cant pull it up hard enough to get it out of reverse with my feet without hurting my toes. I thought maybe i need to get some steel toed boots, but decided i really need to fix it.
I was thinking something like tyres wearing differently front to back that had caused a gradual difference between front and rear ration.. causing binding. Try slipping it in and then straight out again without moving. If it comes out then , then it is binding up. Or, try slipping it out while the bikes moving, and in particular try blipping the throttle just as you go to slip it out so the load comes off the gear. Also perhaps try driving straight backwards without turning and then again turning the steering to see if that makes a difference.. If any of those things makes a difference then it's probably a binding up between front and rear putting a load on the gears.
Other than that, some part of the linkage going over center ? So it has good leverage pushing into gear but then goes too far so the lever is at a steep angle.. But that may not be an option in the case of a yammy..
mine does that sometimes. i just kinda rock it a little and get it back in neutral.
but....it also will go into reverse by itself if i accidentally push past neutral into reverse mode, so maybe it's not going out of reverse?  I'm thinking i need to adjust the cable tension looser. (?)
It doesn't take much to cause what Mga is describing.. needing to rock the bike to get it out of gear. Having new tyres one end and half worn on the other end can do it, even having unevenly/incorrectly inflated tyres can do it.
I've "fixed" people's 4x4 trucks that were "stuck in four wheel drive", by blipping the throttle in gear just before I slipped them out of gear.
So yours will just go in reverse without turning the switch. I always turn my reverse knob switch but have never tried it without turning it so it may not be doing anything either. Last time i rode it i had trouble with the neutral light not coming on, maybe im just not getting it to neutral, but it will roll like its in neutral, neutral has always been hard to find, pull up too hard and it goes to 1st just pull up gently to find neutral,. I think whatever is happeninng might be related.
no...i have to turn the switch for reverse.  just sometimes if i push it into that position, it's still in reverse (light on) i replaced the foot pedal with an arm, so i just go back and forth and it comes out of reverse. doesn't happen all the time...just once in a while. maybe it needs more spring pressure to release the reverse cable.?  I'm going to play around with it this weekend. ( the foot linkage had a lot of wear/play in it, making it hard to find gears, so i went with the side shifter instead of replacing the foot linkage...my cheap way out lol )
right now, i've been using it to drag logs out of the woods that i cut a couple of years ago. gotta say, that thing has the power to pull them out and some were big logs.
Edited by mga
On 11/17/2023 at 11:30 AM, Gwbarm said:
That sounds exactly what mine is doing I remember your post about the hand shifter thought it was a good idea because of this problem.
also, after replacing the boots and lower ball joint, i backed the clutch off a little....that seemed to help. My theory (probably wrong) was that my clutch was still engaging making it hard to get out of that damn reverse...so, i loosened the nut and turned it CC. I might do a little more after i ride it.
    • By Thumpinhard25
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Frank Angerano
