Rear A-Arm bushings
By geezer99
I have an Axis 500 made by Hisun. I uses a solid rear gearbox with no differential action.
I would like to convert this to a true differential with locking ability. I've searched all over trying to find a source with no luck.
Has anyone done this before, or know of a source?
Thanks, Tom
By anthonyd256
By McG75
By jashadams
So I installed a new shock on my 125 yesterday sadly it wasn't adjusted right I took it off to adjust it tried to install it again today and it no longer fits I loosened the nuts on the spring again and it still won't fit idk what I'm doing wrong when I try to install it but I'm lost any tips or videos would be great thanks.
