By pastorjeep
Ok guys, I am a glutton for punishment! I picked up this 01 2wd Rancher because the plastics looked good on the marketplace. It has been sitting in the guys back yard for 10 years. The original engine blew and they swapped in an electric shift 4x4 engine. 😒The engine is locked up and was full of water. The wiring is hacked where they tried to get it to run and the rear end needs new swingarm bearings where they left it laying on the ground in the woods for 10 years. Has anyone here ever did the engine swap? First thing is to straighten out the wiring and get the engine free to see if I can get it to crank over. I have swingarm bearings ordered and a new ignition switch. So hopefully I can at least roll it around soon. 🤣
By TimothyLindblom
Hi everyone, I’m new here and new to 4 wheelers. Just got a Yamaha bear tracker 250 and joined here to see if I could get some help.
The motor runs and it drives if it up on jackstands but if you get on and try to ride it, it starts to drive but then quits after a foot or two and dies out and won’t drive. The guy I got it from said he was running and using it shifting through all the gears great and he started it up the next day and it started this.
He told me he thought it was the U joint on the driveshaft. He said it was probably worn and needed to be replaced.
I just finished pulling the swing arm and rear end assembly to check out the U joint and there’s no play in it. It’s tight and not nearly enough play to be loose enough to not catch and go.
Any ideas on what it could actually be?
Timothy
By mga
2000 Big Bear 4x4 400.
do the front and rear drive shafts have to be lubricated? they have boots on them and i was wondering if i had to pull the boots off and grease the "U" joints? These are the ones close to the engine front and rear.
