No Power on two wires in the Light Pod. (2020 Polaris 850 Sportsman)
By BuckBilly
By dstoltey
I have a 1992 Kawasaki Bayou, and every time I try to replace the fuse on the starter relay, it blows immediately. I have replaced the battery, and have exhausted all of my ideas. Any help is greatly appreciated!
By P_syko
By gt_jacket
Hi,
I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in. Neutral and Reverse lights work.
But when trying to start in neutral, there is no click or attempt to start with the push button.
However if i pull up on the shifter (not hard enough to shift into first though) the neutral light goes off and the start button works and it starts fine.
All gears shift fine with no issues, has anyone seen this before? Just wondering if it is a bad sensor or something needs adjusting.
Thanks for any help you can provide.
