I am thinking about adding a winch. Should I mount to the front or in tow hitch socket? Are there tow hitch versions for sale. I was wondering about pros and cons
If you're doing a front mount, try not to mount too high as this pulls down and buries you in the goo. If wanting to be able to use front and rear, I would look for removable mount like the small trailer hitches, and a heavy duty cable plug so you can just plug it in front or rear
    • By Tim Keiper
    • By Panupong Pradchaphet
    • By gwares
      Price : 4500 EUR
      The Kymco CV3 is a pioneering three-wheeled maxi-scooter that combines the agility of a motorcycle with the stability of a trike, catering to riders seeking versatility and performance. This can be ridden on a car license!
      Key Specifications:
      Engine: 550.4 cc parallel-twin, liquid-cooled
      Power: 51 bhp (38.1 kW)
      Transmission: Continuously Variable Transmission (CVT)
      Fuel Tank Capacity: 15.5 litres
      Seat Height: 795 mm
      Dry Weight: Approximately 280 kg
      Brakes: Dual front discs and single rear disc, equipped with ABS
      Suspension: Independent front suspension with dual leaning wheels; rear mono-shock
      Wheels: Front: 13-inch; Rear: 15-inch
      Everything works and new!
      We try to capture everything in photos for you.
      If you have any questions or need other photos, just ask, thanks.
      Send a direct message to make an inquiry or text:
      WhatsApp: +33 758 56 21 59
    • By gwares
      Price : 2500 EUR
      The Ultra Bee T offers the fastest acceleration of any road-legal electric motorcycle at this price-point, with the flexibility to deal with a wide range of surfaces. With its huge capability the Ultra Bee T will appeal to people looking for a great medium distance commuter, that’s also able to turn its hand to off-road riding and green laning.
    • By qcm413
      Hi,
      Thanks for a newbie on this site !
      i have grinding noise in my front differential. the front right wheel is turning and the left is try to turn but no movement and make sound like a gear broken. somebody have any idea ? not enough oil in diff ?
      thank
