  • Ajmboy changed the title to 1997 Arctic cat 300 No Spark
You have replaced the major parts, I would check to make sure you are getting voltage where it needs to be 12 v to cdi, ground is good at cdi . Check your pick up coil resistance. Did it just quit or what happened.
    • By beast6228
      View File 1986-2006 Kawasaki Bayou 300 service manual
      This service manual is for a 1986-2006 Kawasaki Bayou 300.
      Adding to downloads library.
      Submitter Ajmboy Submitted 05/11/2018 Category Kawasaki ATV
    • By JMSwed
      Hi EVERYONE
      New member here
      CARFAX https://www.carfax.com
    • By mmikesell
