Need help getting desperate. Starts fine but will only stay running if I keep the starter switch depressed. If I let go of the starter switch it dies. This one has me stumped.
Expert advice needed. Thanks
    • By carkivey3
    • By jhamrick75
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
    • By mans
      Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
