The wires may have breaks in them. Wires mostly break right near the end where they go into the metal terminal. You can sometimes detect it by gently flexing the wires one at a time and seeing they feel right..  In this case though it would be better to use an ohm gauge first to test each wire from end to end..
I had a look at the codes and got the power relay for the 14 codes, and the 18 codes seemed to relate to the motor current, or it's current detector circuitry inside the ecu..  Both problems had test/check procedures I saw.. but didn't read.
I suppose you have checked the power relay ?  It would stop any current for the motor, and the ecu would think that was a problem.. problem 18 possibly.
Thanks for the input. I have the 2010 manual and have been following the bunny trail of troubleshooting. but the problem is intermittant. I can't repeat anything to make it happen. I haven't checked the power relay. Where is that? Seems like just heavy wires between ecu and motor.
The manual I was looking in was for 2009-2011..  What does your book say the codes indicate ?
Yeah intermittent is annoying alright. Intermittent probably means it is a wiring problem though..  more so than an electronic problem.. hopefully.
Have you tried leaving it running and then going all over it wiggling the wiring hoping to cause the problem ? You need to be watching the dash while you are doing it to detect which bit of wire it is..  You could also start running a hose over electrical connectors..
Wires get bad connections where the wires crimp into the metal terminals, and they get dirty connections where the terminal contacts the unit, then get breaks, mostly near their ends,  and they chafe the insulation and short to the frame.  All those faults can cause intermittent problems..  The dirty/corroded crimp/connections can be effected by moisture..
    • By pastorjeep
    • By motox88
    • By DaveswMN
      Thanks for any thoughts.
      My 2004 Yamaha Grizzly 660 is still going strong but the battery has not been holding a charge. I replaced it a few years back and have been jumping it lately but after sitting for a few days, it drains out. I recently purchased two car batteries from Weize directly because it was a good price for an AGM. I looked on weize for a YTX20HL-BS and its an AGM at $59.99. I believe they have a promo code you can find. Found it cheaper on Amazon and intalled it yesterday.
      I ended up buying the same one on Amazon which is $49.99 with a $20% coupon bringing it down to $39.99, which is a pretty good price for an ATV AGM battery.
      Just a heads up if anyone needs a new ATV/UTV battery going into winter.
      YTX20HL-BS fits a a good amount of models.
      Arctic Cat:
      Arctic Cat Alterra Arctic Cat ATV 450 Arctic Cat Alterra TRV Arctic Cat Alterra CORE Arctic Cat Alterra XC450 BRP (CAN-AM):
      BRP (CAN-AM) Outlander BRP (CAN-AM) Outlander 660 EFI BRP (CAN-AM) Renegade CF Moto:
      CF Moto Cforce 500 Honda:
      Honda TRX680FA Four Trax Rincon Kymco:
      Kymco Maxxer 450 Kymco MXU 450 Kymco MXU 500 Kymco MXU 700 Polaris:
      Polaris Sportsman Polaris Sportsman Touring Polaris Sportsman XP Polaris Sportsman X2 Yamaha:
      Yamaha Kodiak 700 Yamaha Kodiak 700 EPS Yamaha YFM40FB Big Bear Yamaha YFM40FW Kodiak/Automatic Yamaha YFM40FWN Big Bear Yamaha YFM450FA Yamaha YFM45FA Kodiak Yamaha YFM45FG Grizzly Yamaha YFM45FX Wolverine Yamaha YFM45KD KP Kodiak Yamaha YFM600FW FH Grizzly Yamaha YFM660FP FR FH FL Grizzly Yamaha YFM66FA FG Grizzly Yamaha YFM700DE DH PE PFPH PS Grizzly Yamaha YFM700GD GP Grizzly Yamaha YFM7FG Grizzly Yamaha YFV600FW Grizzly Yamaha YMF5FG Yamaha YFM550PE DE DH Grizzly UTVs:
      Arctic Cat Prowler 500 BRP (CAN-AM) Maverick BRP (CAN-AM) Traxter DPS BRP (CAN-AM) Traxter Base BRP (CAN-AM) Traxter STD BRP (CAN-AM) Traxter BRP (CAN-AM) Defender Kawasaki KAF620 Mule 3000 Kawasaki KAF620 Mule 3010 Kawasaki KAF620 Mule 3020 Kawasaki KAF620 Mule 3010 4x4 Kawasaki KAF620 Mule 4010 4x4 (CN) Kawasaki Teryx All Models (CN) Kymco UXV450 Kymco UXV500 Kymco UXV700 Polaris RZR Polaris RZR 4 Polaris RZR S 800 Suzuki 2005 QUV620F
