Hello, will I need to remove all the plastics to replace the drive belt on this ride? Thanks! 🙂 image.gif.3bf42755759a4470acc533ea265d6c48.gif I've been looking but, can't seem to find the step by step directions/video on how to remove all the plastics.
Ok, I wasn't sure if the bolts were accessible without removing the plastics or not. I've got to get a recoil assembly kit I noticed there is no pull handle. I was going to check the valve clearances but, without the pull rope I can't rotate the engine to TDC like the manual describes. Thanks! 🙂
When you get the side cover off you can put a wrench on the bolt and rotate the engine that way, there should be an access window where you can see the timing marks to get it to top dead center, I can't recall , but the manual should tell you.
    • By carkivey3
    • By jwh
