Hey guys, I'm new on here but I have a hell of a problem.  I traded for a 98 timberwolf 2x4 and it ran good but smoked.  So I decided to get piston and rings with new jug a and put everything together did the timing by the marks on the fly wheel and the cam gear and now all its is rolling over in the back fires extremely loud someone please help
Then, if you're real sure all your work is right, is the fuel fresh, are you really sure the spark plug is firing under the new improved compression ?
 I've checked the timing numerous times make sure it was on the compression stroke rings are on correctly even with  carburetor off and starting fluid it won't start just rolls over and over and back finew spark plug fire's great healthier air won't start
I went out checked to make sure timing was correct on the compression stroke,  it is all correct.  Great fire, new gas/starting fluid,  compression.  Still it won't start,  so I began changing timing by about 10 degrees at a time. The last time before my wife said I had to eat supper it tried to start  But was shooting blue flame out the carburetor.
If you check your timing and it's tdc you could have sheared a key sometimes keys just bend and not shear and throws everything off just a bit. Just A last effort pull flywheel and see if key is good.  Hope the best.
Might pay to confirm the timing mark on the crank is in fact at top dead center.. If you take note of where the crank is when the piston is some certain distance down, both before and after TDC, then halve the distance on the rotor, it gives a pretty accurate check.
To make it accurate you have to be moving the piston up just before taking the measurement..
Edited by Mech
I would agree with mech I use a plastic drinking straw to check tdc when I can't get to flywheel sometimes,just pull plug rotate engine until straw comes up then goes down tweak it until u know it's tdc then look at marks if off then you have a bad key.  Hope that helps you.
I just been reading all the post and thinking about it , I think you are 180 degrees off, even if you were off by a couple of teeth it should still try to start, when you reinstalled the cam were both lobes pointing down.
If both were down your good, im just trying to figure it out, when you installed the cam gear the arrow was at 12:00, both valves closed on the compression stroke, no reason it shouldn't run, did you check the compression after installing new rings.
If the cam timing was off by 180 degrees then turning the crank 360 degrees will bring it to the right place again.
If the rotor key was broken though then the ignition and the cam timing could be right off..
Well guys thank u all very much.  All the input was valuable,  but as I was removing the flywheel I was tired of the junk thing and I beat it with a sledge hammer until the entire crank case was in little pieces.
    • By Atomusthenes
    • By Tim Keiper
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
