It's strange but I don't get much advertising. I'm a paid up member, but even before I was I never got much, nothing that I couldn't dismiss from the bottom of the page with a click of the mouse. If I sign out and come back as a guest I still don't get advertising, but, then, I'm using linux, so perhaps that explains it..  except.. I boot into windows ten, and I still don't see any advertising, no matter whether I'm signed in or a guest..
Perhaps there is some security setting or spam setting I've got right, or perhaps it's when people look in from their phone, which I haven't tried..  but for some reason, some of you sound like you get a lot more advertising that I do.
I reckon there will be a reason though..  Settings I suspect.
Yeah but if I log in as a guest I don't get advertising..  I use mozilla firefox.. for linux, or Win ten with er..  some gimmicky thing..  Edge I think it's called. As a casual visitor I don't get much advertising..
I have all my security settings set to not interact with the world automatically as much as possible. I'm an internet hermit..
When I first signed up I got a few ads, just one click and they go away and after being on for about 3 months started getting more, I was so used to just clicking them off I didn't notice. About a month ago I started getting this square appearing in the middle of my screen and totally locked it until you watched an add, rather annoying. I am using Mac with Safari nothing special. I then decided to join, I had been meaning to anyway, this is the best site iv been on with a lot of activity and helpful people and I wanted to support it and the efforts of the Administrators.
    • By TimothyLindblom
      Hi everyone, I’m new here and new to 4 wheelers. Just got a Yamaha bear tracker 250 and joined here to see if I could get some help.
      The motor runs and it drives if it up on jackstands but if you get on and try to ride it, it starts to drive but then quits after a foot or two and dies out and won’t drive. The guy I got it from said he was running and using it shifting through all the gears great and he started it up the next day and it started this.
      He told me he thought it was the U joint on the driveshaft. He said it was probably worn and needed to be replaced.
      I just finished pulling the swing arm and rear end assembly to check out the U joint and there’s no play in it. It’s tight and not nearly enough play to be loose enough to not catch and go.
      Any ideas on what it could actually be?
      Timothy
    • By heath
      i just bought a yamaha moto 4, i have sprayed 'start ya barstard' into the carb and on the spark plug and it doesnt even fire! although when i have the spark plug on the outside of the motor it shows spark, the engine also leaks oil from the starter,
    • By Banshee898
      2014 Honda Rancher TRX420TM1: Unit starts right up, once it warms up it stalls and more difficult to start but once it does start it won't stay running. I have replaced the fuel assembly, IACV, O2 sensor and fuel injector. There are no active DTC codes. Disconnecting fuel line at injector and turning on key there is a steady stream of fuel. Plug looks good did not see crack in ceramic. Is there any way to test the ignition coil?
      Thanks for any help.
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By WyattLemke25
      Working on a 2016 Sportsman 570 and it has a new battery and spark plug. No codes, fuses all look good. It cranks for a while and when it starts it will only run for a few seconds before stalling. At one point it was running at 3000 rpm with no throttle input, then it dies. Not sure where to look besides messing with the throttle cable, so suggestions are appreciated, Thanks.
