About to acquire first ATV ... interested in two-up (Polaris Sportsman). Need to determine if 500cc will carry 195lb driver and 130lb passenger with extra fuel and light gear. also curious about range on tank of fuel. anyone with experience here to offer guidance?
Yeah it will carry that..
Fuel Capacity 6 gal./22.7 ltr.
Front-Rack Capacity 90 lb./40.8 kg.
Rear-Rack Capacity 180 lb./81.6 kg.
Hitch Towing Capacity 1225 lb./555.7 kg.
Braked Trailer Towing Capacity 1,995 lbs/905 kg
I personally am not a huge fan of Polaris and have seen my fair share of suspension problems on trails. Struts coming a part after hard hits, etc..
I would also check out the Can-Am. Outlander Max 500 EFI
Rotax 500 EFI V-Twin engine
TTI independent rear suspension
Lightweight double A-arm front suspension
Visco-Lok† auto-locking front differential
Continuous Variable Transmission [CVT]
Center Skid Plate
Multi-function full digital gauge
D.E.S.S. electronic anti-theft system
Steel Racks with 300-pound [136 kg] capacity
26-inch radial tires with steel wheels
Ergonomic passenger backrest
Convertible rack/seat system with totable storage box
Raised floorboards
Multi-position passenger handgrips
Driver lumbar support
Outlander MAX 500 EFI | Outlander MAX 500 EFI XT- Can-Am
500 cc will have the power but if u want good range on the gas i wouldn't go to much higher on the cc scale cause u will eat up more gas...
can you offer a ballpark guess on range achievable per tank of fuel?
apparently there are other two-ups available ... will be wise to consider those too before making a final decision ... thanks to all who have responded to this request for info; very useful input from everyone.
    • By mattgoodwin
      I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
      Just checking to see which differential oil everyone is using: Valvoline, Lucas, Honda,Yamaha etc.
    • By drobbie98
      Hey all, Thanks for having me in the forum. I just purchased my first ATV and am stoked to understand more about it.
      The first stupid question will be, what is everyone's maintenance schedule? DO yo follow the recommended intervals or build one yourself based on the machine.
      Thanks in advance.
    • By autocustomizer76
      Hey all got a Kawasaki 300 that's seen better days I'm looking to get running.  But first, I'm working on a Honda 350 ES and mainly needing where are you all finding quality parts at good prices.  Atvs are really hot items around here right now and most of the folks wanting and needing them are not familiar with working on them.  I'm looking to find a good resource for information and if it works out well pass this group along to the folks I help to get them in the know how to get the most out of their machines.  Thanks in advance.
    • By blasirl
      I am in need of a breather tube diagram for my Rancher.  This picture is all I could find in the manual I have.     If you have the hose size and/or lengths needed that would be a bonus.
