1993 Trail boss 350L 2 stroke boggs down after 200 yards running normal
Go to solution Solved by andyt,
I have a 1993 Polaris Trail Boss 350L 2- stroke.  after about 200 yards or so of driving the motor boggs down.....it will stay idling but if I floor it, it will die.....if I turn it off and wait a few minutes I can turn it back on and go like hell for another  couple hundred yards.... I thought the pilot might be worn out(I have it nearly closed now)......maybe the choke plunger isn't sealing or the Bowl isn't filling quick enough.....any suggestions would be appreciated.
  • Solution
Crazy......reserve screen in take was a little dirty and the straw for the tank was up high enough it wasn't getting gas from there.....inconsistent flow from the tank
Oh wow, nice find/fix.
  • 6 months later...
Had the same issue years ago with a 250 2stroke trailboss.  It turned out to the gas tank vent hose.  When it warmed up the hose would collapse shut.  A quick way to check is by opening the gas cap a little and taking it for a ride.  You only need the cap open just a little to allow the tank to vent.
    • By oxidized_black
    • By Sportsman500guy
