1998 trailblazer 250 running away
By Mhatayas
By Sportsman500guy
By Gwbarm
IMG_4910.mov There is some slack in there but most is taken up by the gear cover,if anyone with history with these machines has had the same problem, let me know your findings. Where i am now im looking for finding replacement honda gears on Ebay and try those. I suspect the original was replaced with aftermarket gears years ago and they just worse quality as the years go by.
By TimothyLindblom
Timothy
By Need-help-with-quads
So my moto 4 is smoking white smoke and when I go to first gear and get about half throttle there’s no power and it sounds like it’s bogging
