Well, I’m completely stumped! I’ve been rebuilding a 1990 Big Bear 350 4X4 and finally got reverse to work. Here’s the strange thing, the shifting pattern is all wrong. Reverse is with the lever all the way forward and the forward position is down. What’s the issue? What linkage is backwards? Your help is greatly appreciated!
If you haven;t had the gearbox apart then it's probably just a lever on the outside aiming up or left when it should be down or right..
We have a yamaha guy.. Markin.. ny I think it is. MarkinNY.. He seems to know those things inside out.
According to the pictures in the manual, the linkage appears to be in the correct position. I'm including pictures of the shifter lever position and the selector position. Hopefully that will help explain things. Will MarkinNY see this post too?
Thx
That top photo the cable looks like it has a bit of a sharp bend in it.. Perhaps it gets realigned and attaches to the shift lever differently. The bottom lever looks like it has to be that way or it will hit the case huh ?
I don't know anything about yamahas.. they aren't so popular around here..  Markin looks in from here time to time, but if you post in the yamaha specific thread you might catch him easier..
    • By Tim Keiper
    • By Thumpinhard25
    • By fwsamm
