By Werewolf
Oil is getting in the air box from crankcase vent tube, I put the two hoses that go to the air box together then something started to smoke on the front of the engine. There is a filter? In the line I blew that out.
By Spritee1
having an issue with the unit when running under a load up a hill or in high gear, seems like the belt is slipping, there is a clapping sound coming from the primary clutch like it releases and snaps back in. i don't think I should have a noise like that. this is a friends unit and he has already replaced the primary twice with the same result.
not sure where to look next
By mkibbe
My 2014 750 king quad stalls sometimes when I touch or turn the handlebars,the problem has gotten worse,my machine has 475 miles and is only trail ridden,I have a new factory battery and i have 14.2 volts when the quad is running and 13.3 on the battery when not running,also using a multimeter there is no change in volts when turning the bars until it does stall,If I pull the 40 amp power steering fuse it will not stall.......I've been told its the ECU,Hate to buy one if thats not the problem,but its kinda leaning towards that,,,,,need some opinions.
By ethie
Hi All
not sure where to start
By rgeiser
