2010 4 stroke Polaris Outlaw 50 Dies when brake is released.
Go to solution Solved by rking,
I have checked every switch and replaced both brake switches.  It will run great until the brake is released.  I have checked the Engine ground, and even added another ground.
  • rking changed the title to 2010 4 stroke Polaris Outlaw 50 Dies when brake is released.
  • Solution
PROBLEM SOLVED-
The Tether Switch was hooked up to the Brake wires, and the Brake Wires were hooked up to the tether switch.  Found it by checking continuity from the Ignition switch to the Tether switch, and there was none.  Started checking both the brake wires, since the brake wires and tether switch all have the barrel connectors.  Found it was wired wrong.
Edited by rking
spelling
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
    • By Ethan7387
    • By mans
      Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
    • By mga
      on my left brake handle (for the rear brakes) there's two wires attached to it. What are these wires for? They can't be for the tail light, since it only has on filament  I tried to trace them, but i got lost in the harness. I checked wiring schematics, but didn't see anything like that.
      I'll post a pic later.
    • By Frank Angerano
      I’m looking for any member that may be familiar with the neutral safety switch on this bike.
      I picked up a bayou 220 that I found sitting in a shed. Nice looking bike the guy said it would not start one day and put it away and never touched it again.
      So it turns out the neutral safety switch is bad.  I jumped it out and the bike fired up and runs good.
      I’m more then capable of the work in changing it but this thing is buried pretty good. I’m curious if anyone has done the switch replacement before?
      I attached some pics to see.
      picture 1 is the side view you can see the green and red wires going into the cover.
      Pic 2 shows looking down on the drive shaft coming out of that cover.  That is not a simple cover you just pull off.
      Im wondering how deep and how much sh** has to come off like the drive shaft etc for this switch  to be replaced.
      So if any of the QC members have done this switch I’m looking for any input with regard to changing it.
      Thanks.
