  • Admin changed the title to 1983 Kawasaki KLT200 Spark Issue
If you're really sure it is a spark you are hearing, not a relay buzzing say, then the only thing that will make a spark you can hear will be the cdi unit firing the coil. Listen right up close to the cdi or coil, or disconnect the coil and listen, then disconnect the cdi and listen. The coil won't be firing by itself, but it might be because the cdi is faulty..
    • By carkivey3
    • By jhamrick75
    • By Ethan7387
